Legión Land Rover Colombia • Ver Tema - ADAPTACIONES
ADAPTACIONES
Re: ADAPTACIONES
Notapor defender 90 » Mar Ene 18, 2011 12:37 pm
PARA LOS PURISTAS :grin:
Series Land Rovers
Engine Conversions
Or that 2.25l just doesn't cut it anymore by Dixon Kenner.
There are many reasons why you should not change the stock engine in a Series Land Rover. They include divorcing yourself from a wealth of material aimed at supporting this particular engine. They include:
1. Unparalleled service manuals. There is almost no other engine, excepting the A-block in the austin Mini, the air-cooled VW Beetle engine, and possibly others, that have available the excellent factory manuals for maintaining this engine. Third Party manuals abound, but really cannot compare to Land-Rover's Factory Manuals.
2. The ease of maintaining the engine. From the Land Rover mailing list, a large network of clubs, to others with experience with the standard engine offer a large community to assist you in supporting this engine.
3. Parts availability. All of the parts for this engine, short of the original blocks, are available from somewhere. Refurbished blocks are available, as are heads and other parts. They are cheap to maintain. The parts are cheap, there are no fancy electronics, it is a basic Mechano set that you can take apart in your driveway. In fact, short of reboring the block or playing with the crankshaft, much can be done with the engine sitting in the vehicle.
4. Originality. There are many reasons to keep a vehicle original. They include resale value. People tend to shy away from non-standard vehicles. You go and change that engine because you are doing it and will know the results. A potential buyer will not. This is not to say that you should not, many people find some of these conversions desirable, but the audience is much diminished. Assuming that this does not bother you too much, then you can look at potential conversions.
You have decided that originality doesn't count *that* much and you are thinking about uprating, or changing the 2.25l for something, hopefully, better. So, what are some of the reasons to change the your 2.25l lump for something else?
One often heard reason is that you are seeking to reduce fuel consumption. The 2.25l is not that efficient, and is quite an old design. Robust, not particularly efficient, probably because it was envisioned to operate almost anywhere and fuel quality was not the science it is today. Bear in mind simple maths. Work out how many miles you drive. Work that out in 2.25l mileage and come to an annual cost. Now, put in the more efficient engine specs and note that even going diesel is going to take a lot of miles to pay this off. The more you drive, the faster the break-even point. Think years...
A second revolves around better pulling or cruising power. North America is big. If you want to travel any distance to a rally or something, odds are that you will be driving a couple hundred miles. While the philosophical argument on whether the journey is the adventure or the end justifies the means has been discussed in the OVLR newsletter in the past, some people just prefer to go with the flow. Unfortunately, going with the flow on I81 or the 401 between Montreal and Toronto definitely does not mean 55mph forever. You suddenly find that tractor-trailers, cars, and just about everyone else hates you because you are a rolling road block. Being passed by a semi that is doing twenty-twenty five miles an hour faster than you is not many people's idea of "safe". Speed matters...
Point one and two, if combined in a variety of fashions can mean that you want better traveling range. How far can we go today...
A fourth is obvious. Your loyal 2.25l motor has been pining for the fjords of Scotland and is now pushing up the daisies. IE, "it's dead Jim.". A replacement 2.25l, or even looking at that Rovers North or Turner performance engine is going to cost a few pennies. Using the old adage "in for a penny, in for a pound", implies that you can look elsewhere.
Of course, you could have no engine to start with, so see number four.
Options?
Land Rover:
1. Stick with the 2.25l and go with an improved version, read Rovers North, Turner, ACR, et al.
2. Look to diesel. Preferably the 2.5 turbo diesel or the 2.5TDi. (The International 2.8l falls into this near Land Rover catagory as the differences between the 2.8 and the TDi is negligible)
3. Drop in the Rover V8
Chev:
1. 2.5l or equivalent, stock or modified (See RD Conversion)
2. 3.8, 4.1 and 4.9 Straight 6 Petrol Others: to**ta, Volvo, Ford, nis**n Things to consider when you are considering a swap:
1. Do you have both an adequate budget and the time? Playing with non-standard parts equates to time. Either yours, or someone else's.
2. What is the rebuildable life span of the engine in question? Is it a highly tuned machine that requires lots of care and feeding, or is it a forgiving lump like the 2.25l that will motor on for a long time?
3. How will the engine fit in the vehicle? It is a drop in replacement, or do engine mounts have to move (read work, welding, possible $$$). Does it easily mate up with your gearbox,or is an adapter required (is the adapter plate available and if so, does it come with the lit or is it an added expense)
4. Will more power and performance shred your gearbox if applied in some fit of pique?
5. Now you are going faster. Can you now stop? Older Series brakes are not bad when in the best of shape, but if you are doing seventy five rather than fifty five, are you comfortable? Would changing over to booster brakes make you feel safer (have you budgeted for this?) 6. Will the suspension take the load? While the 2.25l weights in at roughly 450 pounds, some conversions weigh more. Or course, some like the Rover V8 reduce the overall weight of the vehicle
7. Who is going to do this? You? Someone else? This leads into the completeness of the kit. Do you want to run around re-inventing the wheel and fashioning parts, or would you rather just pay for someone else's expertise and experience and just drop that in? You can do it yourself and save $$$, or you can have someone else do the work and pay them for their time. Both approaches are possible and both are extensively followed.
8. When you tire of your beloved vehicle, what is resale like with a non-standard motor in there? It could go either way, depending on neatness and whether or not the motor is something fairly recognizable.
TRADUCION A ESPANOL" PATETICA" :rotfl: :rotfl: :rotfl: :rotfl:
Serie de Land Rover
Conversiones de motor
O l 2,25 simplemente no sirve ya por Dixon Kenner.
Hay muchas razones por qué no debe cambiar el motor de stock en una serie de Land Rover. Incluyen divorciarse usted mismo de una gran cantidad de material a fin de apoyar este motor particular. Incluyen:
1. Manuales de servicio incomparable. No hay casi ningún otro motor, con excepción de a y el bloque en el Mini de austin, el motor de Volkswagen Beetle refrigerados por aire y posiblemente otros, que tienen disponibles los manuales de fábrica excelente para el mantenimiento de este motor. Manuales de terceros abundan, pero realmente no se pueden comparar a los manuales de fábrica de Land Rover.
2. La facilidad de mantenimiento del motor. En la lista de correo de Land Rover, una gran red de clubes, a otras personas con experiencia con la oferta de motor estándar de una gran comunidad que le ayudarán a apoyar este motor.
3. Partes de disponibilidad. Todas las partes de este motor, debajo de los bloques de la originales, están disponibles desde algún lugar. Reformado bloques están disponibles, como son jefes y otras partes. Son baratos mantener. Las partes son baratas, no hay ninguna fantasía electrónica, es un conjunto básico de Mechano que puede dar aparte en su camino de entrada. De hecho, de reboring el bloque o jugando con el cigüeñal, puede hacer mucho con el motor de la reunión en el vehículo.
4. Originalidad. Hay muchas razones para mantener un vehículo original. Estos incluyen el valor de reventa. Las personas tienden a asustarse de vehículos no estándares. Puedes ir y cambiar ese motor, ya que se están haciendo y se sabrán los resultados. Un posible comprador no lo harán. Eso no quiere decir que usted no debe, a muchas personas les algunas de estas conversiones deseable, pero disminuye mucho la audiencia. Suponiendo que esto no le molesta demasiado, a continuación, puede mirar las conversiones posibles.
Ha decidido que la originalidad no cuenta * que * mucho y están pensando de han, o cambiando el l 2,25 por algo, es de esperar que mejor. Entonces, ¿cuáles son algunas de las razones para cambiar la su tumor de 2,25 l para algo más?
A menudo uno de oído en razón es que se están tratando de reducir el consumo de combustible. El 2,25 l no es tan eficiente y es todo un diseño antiguo. Robusto y no particularmente eficiente, probablemente porque se fue previsto para operar casi en cualquier parte y calidad de los combustibles no es la ciencia es hoy en día. Tenga en mente simple matemáticas. Averiguar cuántas millas usted conduce. Funcionar en 2,25 l kilometraje y llegado a un costo anual. Ahora, ponga en las especificaciones de motor más eficientes y tenga en cuenta que incluso va diesel va a tomar muchas millas para pagar esto. La unidad de usted más, más rápido será el punto de equilibrio. Piensas en años...
Una segunda gira en torno a tira mejor o poder de crucero. América del Norte es grande. Si desea viajar a cualquier distancia a un mitin o algo, las probabilidades son que usted conduciendo un par cientos de kilómetros. Si bien el argumento filosófico de si el viaje es la aventura o el fin justifica los medios se ha discutido en el boletín OVLR en el pasado, sólo algunas personas prefieren ir con la corriente. Por desgracia, sucediendo con el flujo I81 o el 401 entre Montreal y Toronto definitivamente no significa 55 mph para siempre. De repente, encontrará que tractocamiones, coches y casi todo el mundo odia le porque eres un bloque sucesiva de la carretera. Está pasando por un semi que está haciendo twenty-twenty cinco millas por hora más rápido que el no es la idea de muchas personas de "seguros". Cuestiones de velocidad...
Punto uno y dos, si se combinan en una variedad de modas pueden significar que se desea viajar mejor gama. ¿Hasta dónde podemos llegar hoy...
Una cuarta es evidente. Su motor de l 2,25 leal ha sido omoplatos para los fiordos de Escocia y ahora está presionando hacia arriba las margaritas. IE, "es Jim muerto.". Un reemplazo 2.25 l, o incluso ver ese motor de rendimiento del Norte Rovers o Turner va a costar unos pocos centavos. Utilizando el viejo dicho "en para un centavo, en para una libra", implica que puede buscar en otro sitio.
Por supuesto, podría no tener ningún motor de comenzar con, por lo tanto ver número cuatro.
¿Opciones?
Land Rover:
1. Mantener el l 2,25 y van con una versión mejorada, lea Rovers Norte, Turner, ACR, et al.
2. Mire a diesel. Preferiblemente el diesel turbo de 2,5 o el 2.5TDi. (La l 2,8 internacional cae en esta categoría de Land Rover cercano como las diferencias entre el 2.8 y el ICD es despreciable)
3. Colocar en el V8 de Rover
Chev:
1. 2.5 l o equivalente, acciones o modificado (Consulte conversión de RD)
2. 3.8, 4.1 y 4.9 6 recta gasolina otros: to**ta, Volvo, Ford, nis**n cosas a considerar cuando usted está pensando en un swap:
1. ¿Tiene un presupuesto adecuado y el tiempo? Jugando con las piezas no estándar equivale a tiempo. Suya o de otra persona.
2. ¿Qué es la rebuildable vida útil del motor en cuestión? ¿Es una máquina muy atento que requiere mucha atención y alimentación, o es una protuberancia perdón como el 2,25 l que se motor sobre durante mucho tiempo?
3. ¿Cómo se enmarca el motor en el vehículo? Es una gota en reemplazo, o hacen montajes de motor tiene que mover (lee el trabajo, de soldadura
Última edición por defender 90 el Mar Ene 18, 2011 12:47 pm, editado 1 vez en total
LIVING THE DREAM
defender 90
Re: ADAPTACIONES
Notapor luchope » Mar Ene 18, 2011 12:43 pm
Oscar la traduccion al espaniol esta patetica :rotfl: :rotfl: , creo que seria mejor que nos enviaras el link de la pagina en ingles, creo que es mas facil de leer. :thumbsup:
Re: ADAPTACIONES
Notapor defender 90 » Mar Ene 18, 2011 12:49 pm
LIVING THE DREAM
defender 90
Re: ADAPTACIONES
Notapor luchope » Mar Ene 18, 2011 12:52 pm
:thumbsup: :thumbsup: :thumbsup:
Re: ADAPTACIONES
Notapor SIR RAF477 » Mar Ene 18, 2011 12:55 pm
Re: ADAPTACIONES
Notapor defender 90 » Mar Ene 18, 2011 12:58 pm
estamos aprendiedo MUCHO GOOD DICE EL GRINGO :thumbsup: :thumbsup:
LIVING THE DREAM
defender 90
Re: ADAPTACIONES
Notapor Peter » Mar Ene 18, 2011 3:13 pm
el mio tiene algunas modificaciones q a mi parecer y por ser mi carro jejeje ayudan mucho sea o no original o como les de la gana es mi carro me gusta y no deja de ser land rover
1 balancines curvos en los muelles
2 carburador rochester
3 muelles parabolicos los delanteros originales
4 arranque relacionado
5 alternador lucas de buen amperaje
6 luces hid
7 adaptacion de silla tacera de otro carro de otra marca
8 tenia los dos motores de limpia brisas como los q dice oscar pero ya restaure uno lucas q consegui
9 cocuyos y luces de freno y direccionales en led
10 suspendi todas las barillas del acelerador solo tengo una y contando el pedal 2 menos barillas menos juego menos perdidas de recorrido menos compliq a la hora de tener q reparar algo
proximas adaptaciones
boster original
traseros parabolicos de otro carro de otra marca
td27, hidraulica enduda
originales o no hay de todo asi lo quiero asi me gusta asi anda como el hp cundo quiere, asi molesta cuando le viene en gana y asi es un land rover............
tratare de poner fotos en la noche
:thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup:
Peter
Re: ADAPTACIONES
Notapor luchope » Mar Ene 18, 2011 3:30 pm
Re: ADAPTACIONES
Notapor Peter » Mar Ene 18, 2011 4:06 pm
lucho es un alternador lucas creo q de 130 amp
RTC5084N ALTERNADOR SERIES 3 - LUCAS UNIDAD BRITPART
eso dijo el vendedor (ger johan) jejejejejejeje
esa capacidad de carga la se cuando monte los otros dos bajos al audio de carro y cuando recoja la bateria de gel q adquiri
Peter
Re: ADAPTACIONES
Notapor OMAR » Mar Ene 18, 2011 4:54 pm
