[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4752: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4754: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4755: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4756: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
Legión Land Rover Colombia • Ver Tema - cinturón de seguridad metálico
Foro dedicado a quienes pasan la mayor parte del tiempo debajo del carro.
Re: cinturón de seguridad metálico
Notapor k1000o » Lun Jul 17, 2017 10:31 am
Camilo Álvarez
(+51)944427800
Series III 1978, Sara
Series IIA 1969, Diógenes
Ex-Series III 1982, Kissa
Ex-Freelander 1.8L 1998, Lullu
"Landrovero, no 4xcuatrero"
k1000o
Notapor ACH » Lun Jul 17, 2017 1:44 pm
La verdad es un tema espinoso, yo igual los tengo con unos tornillos "golosos" para pasar la revision, siempre busque como hacerlos si dañar el carro, sin tener que hacer grandes modificaciones y al final la barra, jaula o semi-jaula eran la unica opcion.
Alcance a pensar en usar de dos puntos, los cuales son acordes a esa epoca, asi que visite varias paginas e incluso aqui, se mencionaban unas platinas "originales" para montar punto bajo del cinturon, cerca a la esquina inferior de la puerta, pero luego en el CDA me dijeron que los cinturones de dos puntos no pasaban, cosa que le argumente al "ingeniero" pero de nada valio mi disertación.
Es algo pendiente por hacer bien hecho, pero como empece a "restaurar" el Frances, cualquier cosa que no pareciera original no me convencia.
Por ahora no lo saco mucho, es un Land Rover para ir a la oficina" jajaja, pero espero igual poderlo sacar a pasear por esas trochas y pistas que tanto provocan al ser aqui publicadas.
Para los niños atras es mucho mas dificil. como amarra uno a chinos de 5 a 11 años en esas sillas atravesadas????....y poner una banca paralela me parece una catapulta sin montar (de nuevo) una jaula bien hecha. .....solo me acuerdo de la volteada del defender en la cruzada al Orinoco y me imagino mis chinos volando como muñecos de trapo.... mejor no, por ahora.
Lo triste es pensar que creci con mis tres hermanos montando en las sillas de un land rover y Afortunadamente nunca paso nada, mi esposa igual crecio viajando dormida en la parte de atras de uno y no paso nada, pero ahora la conciencia me exije ser mas cuidadoso, asi que aun sigo pensando como los llevare a viajes largos....
Bueno, solo queria escribir un rato y ponerme a tono, la verdad esta pagina me desestresa y calma los nervios.....
Saludos
ACH
ACH
Notapor DiegoACC » Jue Jul 20, 2017 12:41 am
bueno y entonces q tipo de cinturones van en la silla del medio adelante, tres puntos no hay como adaptarlo, en ese caso creo q es mejor quitar la silla del medio para la revision y poner un cubybox o nada, los mios son 3 puntos de competencia adelante y tres puntos convencionales fijos atras, en el medio tengo uno de 2 puntos y en la RT tenia el cubybox, sera x eso q no molestaron?
Santana 1966 SIIa
yankold@legionlandrover.com
Tan despacio como sea posible, Tan rapido como sea necesario, go beyond, above and beyond
En Instagram >>>>>>
DiegoACC
Notapor k1000o » Jue Jul 20, 2017 9:27 am
En la silla del medio es suficiente el de dos puntos.
(sin embargo, casi nunca lo revisan)
Camilo Álvarez
(+51)944427800
k1000o
Anterior
Volver a Taller
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 3 invitados
