[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 379: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4752: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4754: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4755: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4756: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) Legión Land Rover Colombia • Ver Tema - AHORA SI RESPONDAN PUESSSSS
bueno puesssssssss llego la hora de componer esto ya va mas de un año y nada que montamos algo serio que pasa yo se que la gasolina $$$$ la ··· y la falta de tiempo es $$$$$ dura pero vale un huevo la idea es asi sea salir a botar coriente no a despedazar lo poquito bueno que tiene los carros ç( aunque esa idea de trocha durito una que otra ves no es mala jajaj ) el caso queines son los del valle que escriban me den los telgonos correos celulares o memande una señal de humo el caso que se hagan notar a ver que programaos es mas ya hasta tengo una ruta pa embarrar los carros un poquito jajajjaa o asi sea que le pegemos una vista al cafe de CRISTIAN EL CASO RESPONDANME HAGANSE NOTA O LLAMEMEN 3158510387
Pollo, la verdad a mi me da mucha pena contigo y con todos los del Valle pero tengo el carro parado hace como 5 meses , estoy viendo la posibilidad, como ya muchos lo han notado, de montarle un motor diesel a mi carro para poder usarlo de nuevo, de lo contrario lo tendre que vender poque necesito un carro tambien que me sirva para cargar pero mas economico de mover... La verdad la situa economica esta medio duronga,afortunadamente con muy buenas perspectivas... espero poder terminar el año con una o varias buena(s) embarradita(s) como las que te gustan.
Oscar estos son tres de nuestros series, El 88 de Pollo, El 109 de Hugo (Sancho) y Mi 109...
Ojalá se reúnan aunque sea para 'echar pola' (pa' eso siempre hay de donde ) ... y ... ¡suban fotos!!!!
Camilo Álvarez (+51)944427800 Series III 1978, Sara Series IIA 1969, Diógenes Ex-Series III 1982, Kissa Ex-Freelander 1.8L 1998, Lullu "Landrovero, no 4xcuatrero"
como dice un amigo mio .no jo da ,,espero que despierte la legion valluna. daniel mi carro tiene un motor Diesel nis**n ld 20 me camina 42 km xgalon tiene muy buen torque pero le falta velocida.. para mi trabajo y mi recreacion no le pido mas. con llantas 7.50 me paso por cualquier parte.. tengan mucho cuidado con la acomodada del radiador ese detalle es clave . saquen el radiador hacia el motor lo soporta con lamina galvanizada.si quieres te pongo fotos de mi motor
